Crooked Bar
Old Aug 8, 2007 | 10:25 AM
madgreek's Avatar
Default Crooked Bar
Just like it reads. When riding, the right grip is closer to the tank than the left. It's off by just a few degrees cw, and the bar doesn't come any closer to the tank at lock cw than it does ccw. Does the bar just need to be pulled off and re-set so that it's straight? What could have caused this?
Old Aug 8, 2007 | 11:17 AM
airick's Avatar
Default RE: Crooked Bar
make sure that your rear tire isn't crooked. that would cause the front wheel to compensate to keep the bike straight.
Old Aug 8, 2007 | 11:35 AM
madgreek's Avatar
That's a good point. Never thought of that. Actually, I believe the rear is a little out of line. You can tell when the front endis up for a while. What's the bestway to line it up?
Old Aug 8, 2007 | 12:17 PM
airick's Avatar
I have also struggled to get my front bars straight. Use the markings on the tensioners for the rear wheel/axle. keeping in mind that you have to account for the chain tension.
Old Aug 8, 2007 | 12:30 PM
madgreek's Avatar
Is there a good write up somewhere about chain tension and wheel alignment? Seems like every time i think I have it right, a short ride around the block reveals that I don't.
cmwatson317
May 29, 2009 09:20 PM
stylin
Jan 29, 2009 08:09 AM
DBEAU
Jul 11, 2008 04:31 PM
willklee
Nov 14, 2007 08:13 PM
jerrad
Jul 18, 2006 01:51 AM
