Anodized Can
Old Aug 8, 2007 | 08:48 AM
madgreek's Avatar
Default Anodized Can
Anyone know anything about anodization? My D&Dis a little scratched up, and I would like to fix it. If not, I thought of painting it with black high temp paint, but Ihave a feelingthe bike would be too plain looking.
Old Aug 8, 2007 | 10:48 AM
410600f2's Avatar
Default RE: Anodized Can
try this for a DIY http://www.duplicolor.com/products/metalcast.html I used it on my valve cover (car) with great results
Old Aug 8, 2007 | 11:43 AM
madgreek's Avatar
Oh ****, I think that "smoke" color would look nice. Thanks man, I might try it. Hopefully it doesn't flake off with multiple heat up/ cool down cycles. This stuff says it's good to 500 degrees intermittently. Anyone know how hot it gets at the inlet to the muffler? I can't imagine much hotter than 350-400 deg. Unless, I'm running lean, that is. (which I'm not)
Old Aug 8, 2007 | 02:42 PM
410600f2's Avatar
Its been on my valve cover for three years and is still holding up, no chipping or peeling. I just spray engine brite on it from time to time and that freshens it up.
Old Aug 8, 2007 | 02:44 PM
madgreek's Avatar
Can you take a pic when you get a chance?
Old Aug 8, 2007 | 02:49 PM
410600f2's Avatar
btw I did mine in red and I found that the least spray you do to get even coverage gives the best effect. If you put it on to heavy it loses the aperance of being anodized and I also used the base coat they sell.
Old Aug 8, 2007 | 02:51 PM
410600f2's Avatar
let me see if I have one saved if not give me a few and ill post one
Old Aug 8, 2007 | 03:12 PM
410600f2's Avatar
here is the problem with pictures... the only ones I have saved(that I can retrieve)with the anodized red are the small parts. At one point I was going to sell the car so I started to put it back to the original condition so the picture I took today is the cover with the base coat only (resembles oem valve cover color) If I can figure out a way, I know I have pictures saved on my old broken computer I can post
Old Aug 8, 2007 | 03:14 PM
410600f2's Avatar
sorry
[IMG]local://upfiles/16169/7B4A2CBC9B0C46B58AAF33845A2806A3.jpg[/IMG]
Old Aug 8, 2007 | 03:16 PM
410600f2's Avatar
here is another
[IMG]local://upfiles/16169/581C077CBF914542BF7D3D36DAA90AD7.jpg[/IMG]
