come on
Old Mar 24, 2008 | 11:06 AM
david s's Avatar
Default come on
dude how theheck do you clutch a wheelieon these things my front end barly budges and doesn't even get off the ground
Old Mar 24, 2008 | 11:45 AM
tao_victim's Avatar
Default RE: come on
mine either haha. i was going about 15 and kept trying, i got up to 9k rpm trying to get it up. but when i clutched at 9k my back tire broke loose and i did a moving fishtailing burnout. front tire still didnt go up.
ohwell
Old Mar 24, 2008 | 01:26 PM
Dj_Squatch's Avatar
Default RE: come on
On mine if the tire is cold or is on a slick spot than itll light up and get all squirly like tao said...but if the tire grips enough I can slip it at about 6 grand in first and itll come up just fine...id do a sprocket kit if I where you so your not tearing up your sprockets dumping the clutch
Old Mar 24, 2008 | 02:37 PM
david s's Avatar
Default RE: come on
so then how do you do it swach it doesn't work how do you do it at slow speeds??i don't know about a sproket kit that too complicated any suggestions has anyone pulled it off if so explain ...please no one likes to leave comments or instructions lol but it would be cool if you did
Old Mar 24, 2008 | 04:12 PM
Dj_Squatch's Avatar
Default RE: come on
well id guess im going around 30ish when I do it.....I only look at the rpms though...which I hold at around 4.5 to 5...maybe 6 grand at the most......push down on the forks....not too hard the first few times you try it...then slip the clutch
Old Mar 24, 2008 | 08:47 PM
smitty911's Avatar
Default RE: come on
i clutch my f2 up easily lol i couldnt really explain it or how it does cuz i dont know but it works lol my first time scared the crap out of me because of how fast it shot up. i almost fell oh wait when i stopped i did fall lol the little pin on my kickstand poked through my shox. i felt dumb
Old Mar 25, 2008 | 02:01 PM
david s's Avatar
Default RE: come on
thanks smitty and dj swach, I think the problem is that I'm not pushing down on the forks????this weekend I'll try again. I'f any one knows anything else please write i would appreciate it.Cool it's time to get hurt
Old Mar 25, 2008 | 05:29 PM
david s's Avatar
Default RE: come on
do my legs have to be in some weird position like one covering the rear brake and the other on the left passanger stand>???????????????????????????
Old Mar 25, 2008 | 08:56 PM
smitty911's Avatar
Default RE: come on
if it doesnt want to come up when you clutch it try bouncing it a tiny bit when you pop the clutch. just to take a little more weight off the front.
Old Mar 25, 2008 | 09:07 PM
Dj_Squatch's Avatar
Default RE: come on
yea you can do it that way but I dont
