Charging and petcock issues
Old Apr 7, 2009 | 05:13 PM
nodaker's Avatar
Default Charging and petcock issues
North Dakotas 101 inches of total winter snow accumulation is nearly melted completely...so im getting ants in my pants.
I just bought a new battery and stuck it in this week. The battery seemed weak today when i went to start it but the bike started right up. I thought if I rode it a while the battery should be charged enough. The bike ran about 20 minutes and I stopped for gas. Go to start it again and sure enough battery is dead. Ended up push starting it and drove it home.
Question is: Did the bike run long enough to charge the new battery or do i most likely have charging issues? It seems to charge when the bike is running simply because the headlight gets brighter with more throttle.
Also, I have not owned the bike long, and I have never known the petcock position between ON, OFF, and RESERVE. Can anyone tell me what positions those are?
Old Apr 7, 2009 | 06:41 PM
Clorox09's Avatar
If it was your charging system it wouldnt of pop started and drove home. Sounds like your battery. Check water levels in it. you drove it long enough to charge. i would try checking what the charging voltage is tho. Also make sure at the battery that all connections are tight
Old Apr 7, 2009 | 07:21 PM
nodaker's Avatar
The battery is brand new from Interstate batteries and they are very reliable. Probably the most reliable in this area. I do not believe it is a battery problem, and you cant check water levels on this battery for it is sealed.
I got a good charger for it, but im afraid it will last as long as the charge will last!
Any ideas on the petcock? I could use trial and error but i dont want to get stranded!!
Old Apr 8, 2009 | 12:52 AM
Memphistn3000's Avatar
if u have a muti-meter this will def. getting get you back on the rode. last season i had the same problem and i followed these steps and found it was my r/r which might be your problem also. linky
https://cbrforum.com/forum/general-tech-stickies-106/how-diagnose-charging-system-51691/
Old Apr 8, 2009 | 01:03 AM
http://downloads.hondatech.info/Moto...e%20Manual.pdf
linky
oh yeah u should download a manual this will come in handy in the future.
middle= off
up=res
down=on
good luck with getting that bike back running!!!!!!
Old Apr 8, 2009 | 01:38 AM
nodaker's Avatar
Alright thank you! I will check the R/R out, or maybe might as well order a new one? Is the Stator possible going bad? I would hate to have to replace that! And thanks now i wont worry about running out of gas again! Thanks for your help guys!
Old Apr 8, 2009 | 10:30 AM
jus remeber before u buy anything make sure you do that test first so you can really know whats going bad.
C Average
F2 Tech
Jun 28, 2010 07:39 PM
joelacer
Dec 15, 2009 10:52 AM
phokoff
Nov 11, 2009 08:18 PM
Solsykness
Jun 16, 2009 05:41 PM
rlowride
Jan 30, 2008 10:47 AM
