CBR600F2 to CBR600F3 Front wheel
Old Sep 4, 2013 | 12:38 AM
ambeos5's Avatar
ROTM, Oct 2014
Default CBR600F2 to CBR600F3 Front wheel
can you put a F3 wheel on an F2? i have a 94 that was changed over to a F3 but i noticed the other day that it still had the F2 front wheel on it (Mech. speed sensor in the wheel dead give away) so im wondering if i can swap it out for the F3 wheel i like the way the rotors look on the F3's. Would i need new bearing or spacers?im pretty sure it has F3 forks on it but i dont know how to tell. Suggestions?
Old Sep 4, 2013 | 08:12 AM
sodahyogesh's Avatar
Can you post some pics of the front end. Its not possible to fix the F3 forks on the F2 wheels with F3 rotors. Post a pic and we will be able to tell you what setup you have
Old Sep 4, 2013 | 08:54 PM
ambeos5's Avatar
ROTM, Oct 2014
far as i can tell it has the F3 forks but the F2 wheel and rotors, ill try to get a pic for ya
Old Sep 4, 2013 | 09:01 PM
ambeos5's Avatar
ROTM, Oct 2014
best pic i can find
what i would like to do is put an F3 wheel with the F3 rotos on here but not sure it will work maybe this is why the F2 wheel was left on here i dont know. what it boils down to is "Can an F3 front wheel fit an F2" Using all of the f3's hardware (rotors)". So if i toke an F3's front wheel complete with rotors will it fit my bike without any problems?
Old Sep 4, 2013 | 10:34 PM
coalminer frank's Avatar
What exactly do you mean, " I have a 94 that was changed over to a F3"? What was changed over?
Old Sep 5, 2013 | 12:29 AM
These are not F3 forks, you are still on F2 front forks.
Old Sep 5, 2013 | 02:34 AM
ambeos5's Avatar
ROTM, Oct 2014
its a 94 F2 that someone blew up, i guess they had a F3 with bent frame or something and switched it all out using the F2 frame. all the wiring harness's engine tranny , plastic and ect.
Old Sep 5, 2013 | 02:40 AM
ambeos5's Avatar
ROTM, Oct 2014
well a F2 fender will not fit those forks i tried. and from the research ive done there is no difference between the F2 and F3 fork other than internals i may be wrong but thats what i keep coming up with. if you look at pics of an F2 and F3 fork side by side hey appear to be identical. I know that the F2 wheel had the mech. speed sensor which mine does does so i know by that and the bolt pattern of the rotors that it is a F2 wheel. Like i said this boils down to will a F3 will fit on the bike with no problems even if its F2 forks?
Old Sep 5, 2013 | 03:00 AM
Seems confusing lol. My only doubt is F2 calipers with not fir on the F3 forks and even if it does then F2 wheels and rotors and caliper position with not align.
If you have the F2 wheel, rotor and caliper on F3 forks then you have helped me a lot as i have spare F3 forks and i will put on my F2 wheel and calipers and give away the speedo
Old Sep 5, 2013 | 03:18 AM
ambeos5's Avatar
ROTM, Oct 2014
do we know of a sure fire way of telling what forks are on a bike? part numbers stamped on them or something?
