cbr 600 f2 Running prob
Hi I,am new to this site and have a problem with my 91 f2.
When i take it out it will run for about 30 to 35 miles then it will die on me. If i try to start it it wont but if i wait 5mins then it will start and run for about 2miles then die again and if i wait 5mins again it will do the same go for 2 miles then die so on and so. If i park it up over night next day it will go for about 30 miles again then the problems start again. Have taken to garage but to no avail. PLEASE CAN ANYONE HELP
RE: cbr 600 f2 Running prob
ORIGINAL: mamlin1977
Check your fuel lines and any venting hoses from the tank..first...
It's a fuel delivery problem for sure...
Problem is somewhere between your tank's petcock and the carbs...
Could be a fuel problem, but I think it's your coil getting too hot. This is caused by broken windings inside the coil, causing excessive resistance. Eventually it builds up and can't create a spark. Check out the resistance (ohms) within the primary and secondary sides of the coil. If you do a search on here or google, I'm sure you'll find a good step-by-step.
