cbr 600 f2 Running prob
Old 07-03-2007, 03:53 AM
mamlin1977's Avatar
Default cbr 600 f2 Running prob
Hi I,am new to this site and have a problem with my 91 f2.
When i take it out it will run for about 30 to 35 miles then it will die on me. If i try to start it it wont but if i wait 5mins then it will start and run for about 2miles then die again and if i wait 5mins again it will do the same go for 2 miles then die so on and so. If i park it up over night next day it will go for about 30 miles again then the problems start again. Have taken to garage but to no avail. PLEASE CAN ANYONE HELP
Old 07-03-2007, 05:18 AM
Default RE: cbr 600 f2 Running prob
ORIGINAL: mamlin1977
I want to say you have some type of "vapor lock"....but don't know if that still exists past 1982.
Check your fuel lines and any venting hoses from the tank..first...
It's a fuel delivery problem for sure...
Problem is somewhere between your tank's petcock and the carbs...
Old 07-03-2007, 06:48 PM
Cadaver's Avatar
+1 I had a very similar problem and it ended up being a crimped vent hose. Check your vacuum and vent lines - especially when you squash the tank down.
Old 07-03-2007, 08:27 PM
Could be a fuel problem, but I think it's your coil getting too hot. This is caused by broken windings inside the coil, causing excessive resistance. Eventually it builds up and can't create a spark. Check out the resistance (ohms) within the primary and secondary sides of the coil. If you do a search on here or google, I'm sure you'll find a good step-by-step.
Old 07-03-2007, 09:54 PM
MikeInCtown's Avatar
If it is a fuel problem, if you pop the gas tank open it should relieve any vacuum buildup and the bike should start.
I'd tend to think it's possible that you have an ignition problem as outlined above. Do the checks shown in the service manual.
brads94f2
F2 Tech
05-02-2013 11:49 PM
jk72180
F2 Tech
05-18-2011 07:25 PM
entity-unknown
03-20-2009 11:55 AM
tdiv135
03-25-2008 04:24 AM
OCTOPUS
06-24-2007 02:48 PM
Quick Reply: cbr 600 f2 Running prob
