Catching hell changing clutch plates..
Old Mar 11, 2009 | 01:00 PM
kingyeddi's Avatar
Default Catching hell changing clutch plates..
Trying to get the center *NUT* off. I didnt have an impact and got NOWHERE!! I did some searching, and it seems that the bolt may spin *CLOCKWISE TO LOOSEN*?? Can anybody confirm this?? I also read about a special tool, but I also heard theres guys that did it w/o the tool with an impact... PLEASE help guys!! Thanks
*edited
Old Mar 11, 2009 | 10:53 PM
Sand.Man's Avatar
You are supposed to turn it counter-clockwise to loosen... Lefty loosey...
And it's a nut, not a bolt.
I believe you need to "un-stake" the nut, which means punch/pry the part of the nut that has been punched into the shaft.
Put the bike in gear and have somebody hold the rear brake, then use your impact to loosen the nut.
Old Mar 12, 2009 | 10:24 AM
kingyeddi's Avatar
Sorry I meant 'nut' and 'CLOCKWISE TO LOOSEN'. Just read it somwhere, dont remember where and I'm aware of the direction bolts usually loosen/tighten. Thanks. I have 'unstaked' the NUT to the best of my ability (lol), and as far as holding the rear brake, have you ever installed plates in an F2?? The problem is the clutch center spinning, NOT the engine/rear tire..
Old Mar 12, 2009 | 01:43 PM
gregtutch's Avatar
when i done my clutch all i had to do was unstack the bold then short blasts with my snapon 1/2" battery gun and i came off no bother. doing the same with an air gun would do the same
Old Mar 12, 2009 | 02:01 PM
kingyeddi's Avatar
Ok, cool. And whoever said the nut unthreads backwards was INCORRECT right?? Did you re-use your nut, or did you buy another one??
Also, what did you use to hold the clutch center still??
Old Mar 12, 2009 | 03:29 PM
gregtutch's Avatar
as far as i can remeber it was just a normal thread nut not left handed. if you have a good tourqe setting on your gun then you can get away with holding a driver inbetween 2 of the clutch pressure plate bolt hole bits and short but full blasts. but be careful. that is excactly how i got mine off. i got a new nut for mine i broke the bit that was stacked so when i put it back there was nothing to restack it
Old Mar 12, 2009 | 03:39 PM
gregtutch's Avatar
also getting the bike into top gear stops the center shaft from spinning. getting someone to stand on the rear brake will stop the rear wheel from turnning the therefore acting like the engine brake when you change down a gear. i done mine on my own so never really had that option. if you put it into gear and dont hold the brake then the shaft will turn the bike over as if you where trying to bumpstart the bike. so make sure you are holding that brake hard i would prob be holding front as well.
Old Mar 12, 2009 | 06:42 PM
Sand.Man's Avatar
Yes, I have replaced the plates and springs in my F2...
Have you?
Old Mar 13, 2009 | 12:21 PM
kingyeddi's Avatar
Have you?
Have now ;-) And the only reason I asked is because there was little detail on how to keep the clutch center from spinning.. w/o the 'special tool' or w/e.. I just used the impact and a flathead. Worked o k. The diffreence is night and day (clutch has been slippin since I picked her up). Gas it hard in 1st and the wheel shoots right up... Now thats more like it :-D Shouldnt be long before the new plates get some serious wheelie abuse. Just waitin on this ****en rain to leave :-(
Weegee
Mar 12, 2013 10:33 PM
tokitiger95f3
Aug 8, 2009 11:52 AM
gr8scape
Jan 6, 2009 10:34 PM
wellarmedCr@cker
Oct 17, 2007 07:53 PM
jetson1000
Feb 12, 2007 06:59 PM
