Carb Cleaner??
Old Apr 15, 2007 | 01:49 PM
AlpineCBR600's Avatar
Default Carb Cleaner??
Is it safe too run a Carb Cleaner in the fuel tank?? if so does brand of product matter?? I purchased a "motormaster" carb cleaner.. but im alittle unsure about adding it too my tank.. Feedback would be great! thanks guys!!!
Old Apr 16, 2007 | 09:13 PM
Default RE: Carb Cleaner??
anyone?
Old Apr 16, 2007 | 11:00 PM
edwardtn's Avatar
I have not done it and this is not 'expert' advice, but no one else has responded. I would think that it would be relatively safe. WhatI would do is ensure you use an amount proportionate to the size of the tank...probably only a third of a bottle or less with a full tank of gas. I would also say that if you are having performance issues that led you to a carb-cleaner you may want to take the tank and airbox off and clean the carbs manually...
Old Apr 17, 2007 | 04:25 AM
pasta847's Avatar
u can use carb cleaner in the tank. but i agree that is better to clean the carb manually you gona get more of the build up out and be able to see what is clogged. some times **** gets too built up where ugotta brush or spray the **** out. spent the hour or 2 and do it right.
Old Apr 17, 2007 | 02:21 PM
CBRider93's Avatar
^^^^ agree wit that guy!! but if you just want a quick clean and run somethin through the tank, i'd recommend using " Sea foam" carb cleaner. that stuff is good!!
Old Apr 18, 2007 | 01:18 AM
lee1rbc's Avatar
Don't do it!
http://www.rc51.org/fuel.htm
Old Apr 18, 2007 | 02:48 AM
CBRider93's Avatar
what do you mean dont do it? that website that you posted is talking about octane boosters and different octane gas. they didn't say anything about running carb cleaner thru the gas. i personally have done it for two years now and it's worked just fine. unless i just dont know that i'm hurtin my carbs by doin this...
Old Apr 18, 2007 | 11:49 AM
jbreit's Avatar
Most cleaners and octane boosters are ethanol type additives. If you put the stuff in there is too high of a concentration it can be bad for certain rubber sealing materials and even some metals. So, go ahead and use it, but if it says that bottle is good for 20 gallons, don't pour the whole thing in there.
As for how good they clean, I consider them more of a maintenance cleaner...you have a plugged up jet, you are going to have to clean it manually or replace it. But run a cleaner through once or twice a year, treat your gas prior to storageand that should never happen.
All that said, I use Chevron or Seafoam.
Old Apr 18, 2007 | 01:46 PM
TennesseeCBRF2's Avatar
+1 on doing it for maintenance only. If it's so bad that you're having problems, you should clean them manually.
I use SeaFoam 3 times a year in my gas. Use 1 ounce for every gallon of gas. Run the whole tank to reserve before adding more gas. Additives like SeaFoam lower the octane rating of gas, so take that into consideration. You don't want any pre-detonation or anything.
Old Jun 15, 2007 | 01:56 AM
FNQuickF2's Avatar
^^^So you run @ 3oz. of SF to a full tank? Just pour it in there huh? Hmmm...If it does good, I'll need to jump on this..
RB
garythegrass
Aug 9, 2010 11:49 PM
Kuroshio
Sep 9, 2009 11:45 AM
Kuroshio
Sep 5, 2009 12:29 AM
mk929
Aug 15, 2008 01:55 PM
Juggalo_X
Jun 20, 2008 08:47 AM
