can't keep my chain tight?
Old 08-24-2008 | 08:22 PM
ggoodling's Avatar
Default can't keep my chain tight?
This may be a stupid question and I'll be the first to admit that I am on the beginning of the learning curve with bikes. This is my first bike and I love it to death but every time I pull something apart I think, this isn't like a car at all....
Anyways, my chain keeps coming lose. I have to tighten it up every 150/200 miles and that is just normal riding. Do I need new sprockets and a new chain? How tight should the chain be when I tighten it up. I have been trying to make sure I don't over tighten it.
Thanks in advance for the help.
Old 08-24-2008 | 08:31 PM
lonewolfcbr's Avatar
Default RE: can't keep my chain tight?
download both the common service manual and the f2 specific one off of this site, i think the links are in general tech, they will give you pretty much all that you need
Old 08-24-2008 | 08:36 PM
edwardtn's Avatar
There is an indicator on the chain tensioner that tells when the chain needs to be replaced. You shoul be able to move the chain up or down 3/4 of an inch in between the sprockets. You may pull out the axle and chain tensioners and check them. I have seen one before where the threads were messed up on the tensioner and because it was hard to turn the guy was not getting the chain tight enough on one side. Either way, you should be going 1000 miles before even thinking about tightening.
PlayfulGod's Avatar
you are pose to check n adjust as needed every 300 miles or so. If you are getting it too tight it will wear the sprockets faster. When it comes to the chain, looser is better than tighter.
Old 08-25-2008 | 10:59 PM
ggoodling's Avatar
thanks for the help guys
OneFastGSR
09-27-2012 12:23 AM
fastcbr
03-07-2009 11:37 AM
sk8r20
06-27-2006 11:21 AM
Angryviking
05-10-2006 08:43 PM
clean929
06-21-2005 12:24 PM
Quick Reply: can't keep my chain tight?
