cant find section 1 of pdf manual
i would really like to have section one of the pdf manual so i can reference to it through all the work i will be doing on my bike if anyone can help please let me know thanks alot guys
The PDF version that is floating around does not have section 1, as they expect you to buy the manual, rather than download it for free.
I definitely recommend you source a hard copy of the maunual - I've found them online in the past, for as low as $10 to $12, and I've found the Haynes, which is the one I use the most, for as low as $15... it will definitely be worth it in the long run, to pick up one of those, or even both.
The only way you'll end up with the whole thing otherwise, is if someone took the time to scan every page, create a PDF or Word document out of it, and send it to you.
