Cam chain tensioner cbr600fm
Hi there
I would recommend that you go with the manual one, the F2 oem has a history of failure.
Been using a manual one since getting my F2 haven't had a problem, just needs adjustment every so often
Thanku, I've bought a manual one now how often does it need adjusting?
You only really need to adjust it when you hear the chain rattle, just to be safe I check and adjust (if necessary) with oil changes.
if I remember correctly there's a post on the manual tensioner install on the form, if I find it I'll link it
https://cbrforum.com/forum/f2-tech-93/cct-replacement-fix-engine-rattle-good-91238/
