broken pilot screw pin
Old Aug 6, 2008 | 07:59 PM
punkfish's Avatar
Default broken pilot screw pin
I have a 91 F2 and when i was cleaning the carbs i pulled one of the pilot screws out and the pin at the end was missing, under closer inspection i realized that the last person who cleaned the carbs must have tightened it to much and the pin broke off inside.
has anyone ever run into this before? anyone know how to fix this problem?
Old Aug 8, 2008 | 12:23 AM
punkfish's Avatar
Default RE: broken pilot screw pin
bump
Old Aug 13, 2008 | 10:21 AM
punkfish's Avatar
no one has ever had this happen?
Old Aug 13, 2008 | 11:17 AM
cowboy from hell's Avatar
only 2 ways to go about this, either use a good compressed air through a blow gun with a really small tip on the end or try to find a magnet thatll reach inside?piece of wire etc. are you sure the tip is still in there?
Old Aug 13, 2008 | 11:32 PM
punkfish's Avatar
100%, it is the only one that when i look inside has a brass circle where the hole should be. i tried using a can of compressed air but that didn't seem to do much. i am going to try the magnet or attempt to heat it and then try the compressed air.
hamlin6
Apr 6, 2013 03:01 PM
pgilmore
Nov 29, 2012 12:39 AM
DragonCBR
Apr 24, 2011 10:34 AM
kerosene
Apr 21, 2011 01:23 PM
Sproutf3
Jul 5, 2008 04:28 PM
