brakes??
Old Mar 25, 2008 | 09:58 AM
quadracer18's Avatar
Default brakes??
hey guys, i put on a new rear tire the other day and accidentally pressed the rear brake and it caused the piston to move out therfor not giving enough clearance to reinstall it... so i used a c-clamp to press the piston back slightly so it would fit. Now after everything is put back together, the rear brakes are not working at all. I feel slight pressure from the piston on the caliper if i feel very closely but other than that its not working. I checked fluid and tried bleeding them. Fluid comes out of the bleeder hole when i bleed the brake but it still doesnt add pressure, there are no leaks throughout the braking system... I also checked to make sure i was getting the full pull out of the mastercylinder and I am.... Im lost guys, help me out lol. thanks
Old Mar 25, 2008 | 11:51 AM
kjohnson's Avatar
Default RE: brakes??
1.Push the pads apart with a flathead screwdriver.
2.Install wheel
3.Pump rear brake
4.Rock on
Nytmr
Dec 21, 2013 09:16 PM
CBRInfantry
Feb 7, 2011 09:42 PM
hopz
Jun 4, 2009 01:28 AM
radvoem
Dec 28, 2008 08:38 AM
