Blown Headlight
Old Jun 26, 2006 | 09:15 PM
93CBR600F2's Avatar
Default Blown Headlight
I've gone through 2 of the Sylvania HT4 light bulbs in 2 weeks. The Hi Beam side keeps burning out on it. The low beam side works just fine. The Hi Beam will work for a little while then out it goes. Anyone have any suggestions as to what the heck is going on? Thanks.
Matt
Old Jun 27, 2006 | 03:52 PM
Syphen's Avatar
Default RE: Blown Headlight
Check your voltage regulator to ensure that its not putting out too high voltage. Also, take a volt meter and put it across your highbeams and see if its getting proper voltage there. Also, when you put new bulbs in, wear latex gloves or just don't touch the glass at all.
Old Jun 28, 2006 | 04:11 PM
93CBR600F2's Avatar
The light that was in there before, just a plain old bulb, nothing fancy about it works just fine and has been working fine for a long time. Why would the high end bulbs be a problem and the low end work just fine?
Roger cbr
Jan 20, 2014 01:58 PM
ko67
F2 Tech
Mar 27, 2013 05:13 PM
MegatronousPrime
Sep 4, 2010 02:52 AM
Memphistn3000
Jun 9, 2009 03:11 PM
hawkwind
The Hurricane Saloon
May 12, 2009 06:46 AM
