BIG PROBLEM!
Old Dec 29, 2007 | 05:30 PM
cowboy from hell's Avatar
Default BIG PROBLEM!
Ok i just got done instaling a stage 1 jet kit on my 94.well i go to adjust my air fuel screws with the provided tool and my #1 cylinder screw is striped. its looks like its about 1 or 2 turns too lean is it safe to ride it like that or iam i gonna screw something up or lose whatever performance gain i got from the kit.
Old Dec 29, 2007 | 06:11 PM
kjohnson's Avatar
Default RE: BIG PROBLEM!
The tip is stripped?
Old Dec 29, 2007 | 06:31 PM
yup.ive tried everthin i cant get it to turn
Old Dec 31, 2007 | 02:45 PM
kjohnson's Avatar
Sounds like you need a new rack of carbs,unless you are patient.
Old Dec 31, 2007 | 03:29 PM
so its no good to run alittle lean there then?
Old Dec 31, 2007 | 04:02 PM
kjohnson's Avatar
No.You want them balanced/synched.
Old Dec 31, 2007 | 04:11 PM
crap.well i guess i could try geting it out with a left hand drill bit then buy a replacement on bikebandit.that would probly be cheaper than buying new carbs i would think.
Old Dec 31, 2007 | 05:15 PM
land_warrior.rus's Avatar
If everything else fails try drilling it out with a very small drill bit. Once you make a little hole in the screw try lightly hummering a small screw driver into it. Have done it a few times but not on carbs.
Good luck
Old Dec 31, 2007 | 06:28 PM
thanks for the advice.i think ill try that.
Old Jan 3, 2008 | 07:34 PM
damn i cant get this picture to post i know it would help anyway some dude told me today that what iam adjusting isnt the fuel screws.what iam trying to turn is all the way on the bottom of the floatbowl imbeded in it when you turn it all the way out i little needle is on the end.
