BIG PROBLEM!
Ok i just got done instaling a stage 1 jet kit on my 94.well i go to adjust my air fuel screws with the provided tool and my #1 cylinder screw is striped. its looks like its about 1 or 2 turns too lean is it safe to ride it like that or iam i gonna screw something up or lose whatever performance gain i got from the kit.
RE: BIG PROBLEM!
The tip is stripped?
RE: BIG PROBLEM!
yup.ive tried everthin i cant get it to turn
RE: BIG PROBLEM!
Sounds like you need a new rack of carbs,unless you are patient.
RE: BIG PROBLEM!
so its no good to run alittle lean there then?
RE: BIG PROBLEM!
No.You want them balanced/synched.
RE: BIG PROBLEM!
crap.well i guess i could try geting it out with a left hand drill bit then buy a replacement on bikebandit.that would probly be cheaper than buying new carbs i would think.
RE: BIG PROBLEM!
If everything else fails try drilling it out with a very small drill bit. Once you make a little hole in the screw try lightly hummering a small screw driver into it. Have done it a few times but not on carbs.
Good luck |
RE: BIG PROBLEM!
thanks for the advice.i think ill try that.
RE: BIG PROBLEM!
damn i cant get this picture to post i know it would help anyway some dude told me today that what iam adjusting isnt the fuel screws.what iam trying to turn is all the way on the bottom of the floatbowl imbeded in it when you turn it all the way out i little needle is on the end.
