Bar end ?
Old 03-11-2009, 04:52 AM
wforeman87's Avatar
Default Bar end ?
Hey guys,
I have a set of bar ends and when I put on the throttle side it makes the throttle stick. Even when I dont have it tight the throttle slowly goes back forward. Not snap back. With the bar ends off it works fine. So is there any thing Im doing wrong? or what could I do to make them work?
There not factory bar ends. Ive tried shaving down some of the aluminum (diameter)on the bar ends to see if it would help but no luck. Any suggestions will be very helpfull and appericiated.
Thanks in advance
Old 03-11-2009, 08:33 AM
Sand.Man's Avatar
Cut your hand grips back so they don't touch the bar end
Old 03-11-2009, 09:55 AM
flyboy1011's Avatar
I second hersh on this one...I just put new grips and bar ends on mine and had to cut probably 1/4 of an inch off my new grips...good as new
Old 03-11-2009, 10:20 AM
wforeman87's Avatar
ok thanks ill go try it.
Old 03-11-2009, 01:33 PM
smitty911's Avatar
Same problem here. i had to shave some of my new grips off so it wouldnt rub on the bar ends.
