94 cbr 600 f2 valve specs?
Old Mar 15, 2014 | 12:05 AM
Nick Smith's Avatar
Default 94 cbr 600 f2 valve specs?
Hey guys pulled the bike out this morning dewinterized it changed the plugs ect... but just cant get it to run got spark got compression and carbs are clean tried pulling it down the road and got nothing keeps backfiring when cranking it over flames out the exhaust the whole 9. So I figured it jumped time when I tried to pull it down the road. Pulled the valve cover off its in time but I thinking one of my valves might be burnt bent to tight idk but can anyone give me the specs on valve clearence cant find it in the manual. Thanks!
Old Mar 15, 2014 | 12:34 AM
CorruptFile's Avatar
June 2013 ROTM
IN: 0.13mm - 0.19mm
EX: 0.19mm - 0.25mm
COLD!
Old Mar 15, 2014 | 11:02 AM
Nick Smith's Avatar
Ok valves are in spec I have compression and spark the plugs are wet so its getting gas why wont it run!!! Its 40 degrees out but it should still fire up it ran when parked any suggestions?
Old Mar 15, 2014 | 04:56 PM
gtcole's Avatar
Welcome Crew
You said plugs are wet, are they getting spark?
Old Mar 15, 2014 | 11:48 PM
SJN's Avatar
SJN
Igniter leads on the correct cylinders ?
Old Mar 17, 2014 | 08:56 AM
JNSRacing's Avatar
Welcome Crew and ROTY 2014
Do a spark test - make sure you're getting a nice hot blue spark.
Old Mar 17, 2014 | 12:56 PM
squale147's Avatar
July 2013 ROTM
Old Mar 18, 2014 | 01:04 PM
Benjy68's Avatar
I had this problem on a cbf125 it turned out that the sparkplug was faulty. Put it to the engine to test and it was arcing to the casing and not to its point. Changed plug turned it over and away it went. Just a suggestion.....
Old Aug 4, 2014 | 02:36 AM
Nick Smith's Avatar
Changed the plugs cranked it over 1 time and away she went. I didnt know plugs could go bad from just sitting through the winter? I changed them when I parked it they just wouldnt fire under a load. thanks man!
Old Aug 5, 2014 | 01:48 PM
JNSRacing's Avatar
Awesome! Glad to here you're running, I thought you gave up and sold it or something!
HELIGUY02
Feb 26, 2013 05:29 AM
cz976
Jan 5, 2009 05:14 PM
abs929cbrrr
Oct 17, 2008 12:30 PM
pchap428
Sep 28, 2008 01:03 PM
pchap428
Sep 25, 2008 04:46 PM
