91 CBR Temp Gauge Help
Old Nov 9, 2012 | 07:40 AM
R3define's Avatar
So I grounded the gauge and it moves. Which is good. However, I had to completely disassemble the cluster and when I pulled the temp gauge the needle rotated as i turned it but never went back to the pin. It just stayed where I left it. I'm not sure if that is normal for temp gauges or not. :/
Originally Posted by adrenalnjunky
Ahh - then I confused 2 new F2 owner's intro threads.
Sorry bout that.
but, to help you out, yeah pull the cluster out and ground at the gauge first - see if it operates. Then lets go from there.
Sidestand bulb being lit is one thing, but weird cause I thought signal to light that bulb, should kill the motor as well. Lemme revisit the wiring schematic.
Old Nov 9, 2012 | 09:19 AM
adrenalnjunky's Avatar
hmm. I recently had to do the same test on the temp gauge in my truck. what I think happens is that when powered up, grounding the gauge moved it, but ungrounding would let it return to the normal location. But if the truck is hot - the needle moves, and if I kill power the needle stays where it is, until I put the key back in and it resets.
Have you reapplied power to the bike without the cluster grounded to see if it returns to normal?
Old Nov 9, 2012 | 10:18 AM
R3define's Avatar
Well. It moves when just sitting there. It goes to around the middle then stops. Lol. I'm going to go for a ride this afternoon (it's gonna be cold) when I get home.
highflying23
Nov 14, 2013 04:03 AM
90cbr600f
Jul 16, 2012 06:49 PM
scottiekarate17
May 8, 2012 07:12 PM
tylerdaly89
Jun 28, 2008 06:05 PM
