900 swap
Old Jan 9, 2008 | 07:00 PM
cowboy from hell's Avatar
Default 900 swap
ive heard alot of people doing this. how hard is it? what kinda cost iam i lookin at?is it worth it all?
Old Jan 9, 2008 | 07:24 PM
radtechrider's Avatar
Default RE: 900 swap
Check with bendelsf2. I think he did a 900 swap. Wouldnt mind doing that myself. Let me know the cost and difficulties
Old Jan 9, 2008 | 08:39 PM
bindelsf2's Avatar
do a search there are a bunch of articles from me and RSP919 on it.. i will look for them too.
it wasnt too bad you have to make a motor mount and cut one shorter. the biggest pain is gettting it tuned right because you cant run a airbox. that and i broke a motor mount on the block after the first ride and it cost about 300 to get it welded back on because it was alum. and they had to be careful because of the seals. that and making sure that the front and rear sprockets aligned right. i think i had about 1200 total in the swap.
Old Jan 10, 2008 | 04:26 PM
okay i found some posts. does this swap take away from the agility or balance of the bike? good for stunting or track day?
Old Jan 10, 2008 | 06:49 PM
rsp919's Avatar
CBRF 2009 AOTY !!
Not at all. In fact, if I remember right, the 900 motor is only 1 lb. heavier.
Old Jan 11, 2008 | 03:24 PM
Sand.Man's Avatar
Furthermore, what year 900RRmotors fit in the F2?
Old Jan 11, 2008 | 09:16 PM
rsp919's Avatar
CBRF 2009 AOTY !!
93-99
Old Jan 11, 2008 | 10:06 PM
bindelsf2's Avatar
i used a 93 900.. make sure to check for the infamous 2nd gear pop out.. alot of the 900RR's have the gear dogs stripped on them and the bike will pop out of gear in 2nd when you get on it pretty good mostly from wheelies without using the clutch. i have that problem on the engine that i bought and i replaced the shift forks but it is still doing it. now i am rebuilding the trans..
Gnarly 928
Oct 10, 2012 11:46 AM
Bringingf2bak
F2 Tech
Apr 23, 2010 03:22 PM
stretchedf2
Dec 22, 2008 09:42 PM
410600f2
Aug 20, 2007 08:08 PM
