1993 CBR600F2 Fuel Issue
Old May 26, 2025 | 04:45 PM
Koda2864's Avatar
Default 1993 CBR600F2 Fuel Issue
I've been having issues with my F2 sputtering then losing power. I believe it's an issue with the fuel so I replaced the F2 petcock with an F3, but ultimately I still have to pull to the side of the road and let more gas drain through. There is an external fuel filter plugged between the petcock and engine. I'm pretty sure that's causing it to not receive enough fuel and the fuel filter itself isn't supposed to be there from parts diagrams I've looked at. If anyone can confirm my suspicion and if this would help it run properly I'd appreciate.
Old May 26, 2025 | 09:31 PM
The easiest and quickest thing to check is to open the fuel cap when you get in this condition.
If the bike staets running better right away it means you have a clogged or pinched vent tube.
Old Jun 1, 2025 | 04:27 PM
Koda2864's Avatar
Bit of a late reply, sorry. Before posting this thread I took apart the petcock assembly, and checked the vent tubes or air stuck in the tank. There didn't seem to be an issue. I have an image below but I was curious if this fuel filter should exist between the petcock and engine?
Old Jun 2, 2025 | 03:04 AM
Ed Harris's Avatar
Not a standard fitment.
hamlin6
May 16, 2021 08:48 PM
Red97tib
Oct 18, 2015 11:47 AM
95frankenF3
Apr 25, 2012 02:51 PM
kamikase
May 16, 2011 10:16 PM
Krokus_92F2
Feb 3, 2010 07:45 PM
