1993 cbr f2
Old 06-22-2009, 01:28 PM
DRLOWZ's Avatar
Default 1993 cbr f2
Ok heres the story I need help on what to look for:
* Bike started acting funny a few days ago, between the RPM of 5k to 7k.
* Acts like it is starving for gas, starts jerking around....really hard to explain.
So I took 2 sets of carbs and rebuilt another set....SAME PROBLEM
Changed out the plugs.....SAME PROBLEM
Removed air filter..... SAME PROBLEM
This is where I am stuck.....what to look at next...
IF you need anymore details, please, feel free to ask...
Old 06-22-2009, 01:52 PM
nickels's Avatar
I Can't Sell On CBRF
vent hose not venting correct...might have pinched it when you took the tank off
Old 06-22-2009, 01:54 PM
DRLOWZ's Avatar
Vent hose where?
Old 06-22-2009, 02:42 PM
nickels's Avatar
Originally Posted by DRLOWZ
Vent hose where?
vent hoses coming from the tank that run down by the swingarm....sometimes you forget to help them through the bracket that holds them in place and it pinches the hoses when you sit the tank down
Old 06-22-2009, 04:21 PM
DRLOWZ's Avatar
I dont have any tubes or hoses from my tank, does that matter?
Old 06-22-2009, 07:57 PM
Sand.Man's Avatar
You've got a flat spot in your fuel mixture, jetting needs to be corrected
Old 06-23-2009, 12:07 AM
DRLOWZ's Avatar
So I need new jets? What do I need to buy?
Old 06-23-2009, 08:34 AM
Sand.Man's Avatar
Either that or one of your floats is sticking shut, starving one of your cylinders of fuel...
Old 06-23-2009, 09:44 AM
DRLOWZ's Avatar
Hershy, what would you check first?
Old 06-23-2009, 02:22 PM
Sand.Man's Avatar
The floats, do the tip test to see if they are all opening simultaneously.
The only way to be 100% sure your jetting is spot on is with a dyno, I imagine you could have somebody help you tune it for under $300 on the dyno. (but before doing this be sure to sync them)
Quick Reply: 1993 cbr f2
