180 tire + rear fender
would that work?
RE: 180 tire + rear fender
No.
Biggest you should go is 170, but then again, you shouldn't if you have an f2 because the rim is only 4.5 inches which a 160 is suitable. |
I'm running a 190 with the stock wheel and hugger and it works great! [8D]
Hey rick are you reall running a 190?? That cannot be a f2 wheel!! LOL can it?? If so how did you do it!?
ORIGINAL: Rickracer I'm running a 190 with the stock wheel and hugger and it works great! [8D] |
If you guys put wider tires on a 4.5 inch rim, it doesn't increase the contact patch. It will look rounder and not as flat as you guys would expect. And if you are doing that, good luck.
ORIGINAL: Rickracer I'm running a 190 with the stock wheel and hugger and it works great! [8D] a 180 on a f3 wheel looks and rides fine heres mine http://i293.photobucket.com/albums/m...9/P7270399.jpg |
Ill take a pic and post it tomorrow, my camera is at work and Im off today, [sm=happy046.gif][sm=icon_cheers.gif] [sm=shades.gif]
As far as I know, its a stock 93 F2 wheel, and it had a 170 Metzler on it that would spin just cracking the throttle in first and 2nd.I was planning on going up to a Shingko 180, but when I went to my favorite bike shop for a tire, he only had 190s, and thought it would fit, so we put it on, low and behold, it does. My hugger was a little warped anyway, so I had to make some make some wooden wedges and stick em between the tire and the hugger in a few spots, and then warm it up with a heat gun just a little, let it cool and now it fits like a glove, better than it did when I got it with a 170 on it. [sm=shades.gif] |
I'll stick with my 160
Well thats whats up! Can you post the exact mesaurements of your tire Rick??!
