Wire diagram
Old Mar 1, 2018 | 11:25 PM
streetfighter7's Avatar
Default Wire diagram
Checking my headlight diagram because they aren't working. But what are the boxes that the white wire leads too from the headlight? Where are they located on the bike?
Old Mar 2, 2018 | 01:16 AM
tentacleslap's Avatar
The white boxes are connectors. That'll be the right handlebar switch connector. It notes that it's a mini connector, black in color, 9 pins.
Check next to the fuse box. There'll be several connectors held in place by a piece of sheet metal. It should be there
For what it's worth, I'd check fuses and confirm grounds, then check the headlight switch itself. Given that these things are out in the elements they can definitely get a bit crusty
Curious to see some pics of the bike
Old Mar 2, 2018 | 04:29 PM
Light green: horn+
White/Green x2: Rear brake, fuse box, turn signal relay rear blue/white: Light switch, engine stop, starter
Blue x2: Headlight
White: headlight
Teal: Right turn signal, rear turn signal
Gray: turn signal relay rear
Orange: left turn signal, rear turn signal
Green: Negative-
for connecter left handle bar switch
Old Mar 2, 2018 | 10:53 PM
Oh yeah oops. Up here in the wastes it's been so long since the snow started that I forgot what side the headlight switch is on. You're looking for the left handlebar switch connector obviously
josh5288
Mar 15, 2011 12:34 PM
adamw89_2000
Jul 28, 2010 02:17 AM
Mike091
Feb 16, 2010 09:04 PM
Maxboost44
Mar 21, 2008 03:10 PM
InTheMaking
Jul 31, 2005 06:13 PM
