Wire diagram
1 Attachment(s)
Checking my headlight diagram because they aren't working. But what are the boxes that the white wire leads too from the headlight? Where are they located on the bike?
The white boxes are connectors. That'll be the right handlebar switch connector. It notes that it's a mini connector, black in color, 9 pins.
Check next to the fuse box. There'll be several connectors held in place by a piece of sheet metal. It should be there For what it's worth, I'd check fuses and confirm grounds, then check the headlight switch itself. Given that these things are out in the elements they can definitely get a bit crusty Curious to see some pics of the bike |
Light green: horn+
White/Green x2: Rear brake, fuse box, turn signal relay rear blue/white: Light switch, engine stop, starter Blue x2: Headlight White: headlight Teal: Right turn signal, rear turn signal Gray: turn signal relay rear Orange: left turn signal, rear turn signal Green: Negative- for connecter left handle bar switch |
Oh yeah oops. Up here in the wastes it's been so long since the snow started that I forgot what side the headlight switch is on. You're looking for the left handlebar switch connector obviously
