Where can I get a fuel pump?
RE: Where can I get a fuel pump?
Ebay or salvage yard are probably your best bet, you'll pay a fortune through dealer. If you are stuck you can bypass the pump and run it by gravity, F2's are gravity fed. This is not recommended for extended period of time. I had a hard time finding on for an F1, after research I found that the F3 pump would work. I purchased one from a 96 F3 and it is working just fine. Fuel pumps are similar for just about all bikes and made by the same company.
Kopi Ko
10-01-2019 08:29 AM
