What are these plugs/connectors for?
Old Feb 13, 2012 | 09:11 PM
87 cbr 600f's Avatar
Default ur plugs
as summised in earlyer post ,as they are actually the sockets of the rr leads the plugs have been re routed under the tail if u look under the white plastic section u will see the old rr,as said pain to get to hence routed to tail section.
Old Feb 14, 2012 | 12:25 AM
Acespad3's Avatar
so they are just extra plugs now? im curious as well to see if there are any drawbacks or longevity issues due to the rerouting
Old Feb 18, 2012 | 11:22 PM
slowbird's Avatar
Registered Users
Went to see the bike today. The R/R is under the tail section above the rear hugger.
...and as guessed, the wires/leads have been re-wired/re-routed around these plugs.
Old Feb 19, 2012 | 07:40 PM
hurricane1988's Avatar
New Member
what is the r/r that is mentioned?
Old Feb 20, 2012 | 05:04 AM
MadHattr059's Avatar
r/r is refering to the regulator/rectifier. It takes the AC current generated by the stator
coil on the bike and converts it to DC that the bike uses, that's the rectifier part.
Then it caps that DC current at about 14.4-5 volts, since the current out-put by the
stator is variable, depending on RPM.
Ern
Old Feb 20, 2012 | 09:24 AM
slowbird's Avatar
Registered Users
Where is its original location?
Old Feb 21, 2012 | 06:29 AM
Default ur plugs
if u follow the spare sockets u will see the old rr under the white plastic piece, u may as well remove it as to avoid any further confusion,its excess baggage now and not needed.
Migge
F2 Tech
May 6, 2014 11:24 AM
96MTBike
Jan 4, 2014 07:25 PM
nmband13
Mar 26, 2011 09:04 AM
severetitan
Apr 23, 2008 09:56 AM
rrasco
Sep 18, 2006 07:02 PM
