What to do with fuel?
Old Nov 24, 2008 | 01:23 AM
tkm3d1a's Avatar
Default What to do with fuel?
So I'm stripping my bike so that I can work on it and see what needs fixing, but I don't know what to do with the fuel tank. I only see the one hose coming out so if I want to drain the tank do I just pull that off and let it drain into a gas can?
Old Nov 24, 2008 | 03:10 AM
Sand.Man's Avatar
Default RE: What to do with fuel?
Drain it into your car/truck/moms minivan...
Don't you have a petcock? just leave the petcock attached and in the "off" position, and don't lay it upside down.
Old Nov 24, 2008 | 03:27 AM
tkm3d1a's Avatar
ORIGINAL: Hershey
I'm not as up to speed on bikes as with cars, but is a petcock the switch to turn the fuel on/off? If it is, yes I have one but where would I detach the fuel line then? right after it?
Old Nov 24, 2008 | 03:48 AM
Sand.Man's Avatar
Yes the petcock is a flow valve, you detach the fuel line from the aluminum body - make sure the valve is set to the off position (normally horizontal)
That will stop the fuel from flowing through the petcock, a little bit of fuel will spill from the hose so don't freak out.
That's all you need to do: Turn valve off, remove fuel line, set tank aside. Done!
Old Jan 22, 2009 | 02:49 AM
canadian414's Avatar
I wouldn't trust the petcock if i was you. Test it first. I thought mine worked then I had gas leaking all over the place. Best thing to do is just drain it into a gas can from the top of the tank if the off switch doesn't work.
Old Jan 22, 2009 | 03:02 AM
RotorDemon's Avatar
Interesting.. Arrow pointing up is off for me.. Horizontal is on and Down is reserve.
Old Jan 22, 2009 | 09:07 AM
tds94probe's Avatar
thats wierd........
Kopi Ko
Sep 6, 2024 12:02 AM
Mulkxican88
Nov 14, 2013 05:23 PM
Bryantsito
Mar 25, 2012 02:40 PM
Rockshoxtora
Aug 12, 2010 03:58 PM
