what Chain & Sprocket setup should I go for?
Old Oct 8, 2010 | 12:16 PM
itfben's Avatar
Default what Chain & Sprocket setup should I go for?
Hi guys, so winters coming so im guna start cleaning and doing the bike up.
just look to start with chain & sprocket change as it seems really loose and i cant seem to get the chain back any more.
(Just done my oil filter and oil change)
So should I go for off the line speed or top end?
im feeling the off the line to be honest. wheelie machine would be nice, as it was a reasonable cheap bike so I would like to learn to wheelie before i get a RR next year :P (will of course be done on my own private property in a controlled environment)
So can anyone recommend a good setup, also i dont quite understand how it works do extra teeth on the front and less on the back make it quicker off the line but slower top end and the other way round is vice versa so slower off the line and higher top end?
as mcuh info would be great, keeping it simple to start off with to start off with would be helpful but i am fine with research anythign you say that i done understand or i will ask
thanks guys
Old Oct 10, 2010 | 09:22 PM
heresolong's Avatar
I found that mine would wheelie just fine when it was bone stock. FWIW.
As far as the gearing theory, if you reduce the teeth at the wheel you are spinning the rear wheel faster for every revolution of the engine. Keep in mind that the number of links stays the same for a given time period. Smaller sprocket then means that the same number of links is further around the circle.
Same thing only backwards for the transmission sprocket. Increase the number of teeth and you are moving more links for the same rotation of the sprocket. More links, more of a circle when you get to the back wheel.
I am a math teacher and we actually did a unit on this in one of the classes I taught. I took in an old Harley belt and a front and rear sprocket and we painted marks on the sprockets to see what was happening. It was quite fun.
Old Oct 11, 2010 | 11:46 AM
itfben's Avatar
spoke to Demon Tweeks (UK company) and they recommended the following:
Tsubaki Alpha X Ring Gold Chain
Rental Front Sprocket -1 tooth
Supersprox Stealth Rear Sprocket
from what I have seen on the forum that should be a good set up, what do you lot think?
Old Oct 14, 2010 | 05:21 PM
tds94probe's Avatar
You want acceleration off the line go smaller front larger rear
You want more top speed go larger front smaller rear.
To be honest with you it doesnt change your final drive ratio THAT much, you may see 1/4 to 1/2 a second difference in your 1/4 mile times.
I have a -1 front currently and my highway rpm is fine, im thinking of upgrading to a +1 rear.
Old Oct 16, 2010 | 05:26 AM
itfben's Avatar
went for:
Renthal Rear Sprocket
now fitted, rides beautifully now.
Old Oct 16, 2010 | 06:58 AM
RoadiJeff's Avatar
Senior Member & Lord of The Man Cave
The Gearing Commander website will tell you how different size sprockets will change your top speed and rpm. Load your bike's stock setup from the drop-down menu and tinker away.
As far as understanding how it all works think about the gearing on a bicycle. When you shift into a larger sprocket on the rear it makes it easier to pedal. When you shift into a smaller rear sprocket it is harder to pedal but you'll go faster if you're still turning the cranks at the same rpm. Things are just the opposite for the front sprockets (chainrings).
Old Oct 17, 2010 | 05:18 PM
itfben's Avatar
Ye i used that site and all it done was told me my bike would be slower through every gear SPEED wise. gave no indication as to how the acceleration would be increased.
Old Oct 18, 2010 | 07:45 PM
tds94probe's Avatar
a widdle bit
Old Oct 20, 2010 | 12:51 PM
tripicana's Avatar
how often do you ride faster than 55? next chain and sprockets i'm going back to stock setup. the high rpms at highway speeds gets annoying, and i'm always trying to shift into 7nth gear.
Old Oct 20, 2010 | 01:43 PM
RoadiJeff's Avatar
GIPRO gear indicator. It helped me with my 7th gear problem.
Steve Theodore
Nov 14, 2012 11:59 PM
drake5.0
Nov 14, 2012 11:47 PM
pipedcbr
Apr 22, 2011 10:32 AM
Toe-knee
Sep 12, 2010 11:08 AM
A4wheelin
Mar 4, 2008 09:03 PM
