Trick to bleeding front brakes?
Took 30 mins to change my old rubber hoses to shiny new red braided ones. That was last Thursday - still bleeding the brakes now! I'm nearly there. Patience and perseverance seem to be the key.
Also - I've found that ty wrapping the lever (tightish against the bar) overnight then releasing in the morning finds a few more bubbles each day. Think i got the most airated bottle of DOT4 that was in the shop.
Initially took 6 hours of bleeding / pumping / having a cigarrette / swearing before I got any pressure on the lever.
Yes Mattson, done this myself, just make sure you don't overflow the upper reservoir
Cheers, SB
I will have to try that next time. Thanks!
I got one of them - problem I'd the one way valve is crap! Back to using the old way!
