tips on cleaning carbs?
Old 08-28-2006, 12:24 AM
rrasco's Avatar
Default RE: tips on cleaning carbs?
DC...might be the starter link shaft, the choke rod, make sure all the screws are tight and they are all adjusted correctly to syncronize the choke movement for each carb.
Old 08-28-2006, 06:35 PM
I delt with this on my old CB650
Not only did I clean all the jets and carbs, meaning you have to take the bowls off the bottom, un screw the jets and clean em, and soak everything else in carb cleaner, replace the rubber gaskets and stuff. and got them synced by a shop. it ran good.
But my choke cable was sticky and didn't go all the way down, so at idle the choke would still be on a little and caused the engine to die at idle. I'd have to push the choke down manually on the carbs for it to completely disengauge. So I would check this, make sure you choke goes all the way down while using the lever, if it doesnt' you'll have to lube up the cable and such so it works properly.
Hope that helps some of you guys
Old 09-05-2006, 12:07 AM
thanks rras and maxi
jonny_on_the_spot
04-24-2013 07:53 PM
dodger79
09-22-2012 03:31 PM
Hyperblau
02-21-2012 06:29 PM
1weasel
02-15-2011 08:58 PM
captain crash
04-24-2007 03:02 AM
Quick Reply: tips on cleaning carbs?
