Tip for setting air pressure in the fork tubes.
My problem was getting the air pressure set correctly...As soon as I got it close, I would lose pressure while disconnecting the pump.I bought an adaptor that threads on to the air fitting that has its own shut-off. Once I have the correct pressure in the tube I use the schrader adapter to close the tubes schrader valve and avoid losing air. I'll post a picture of the adapter later.
