temp guage not moving
Old 02-02-2010 | 07:53 PM
dewdog's Avatar
Default temp guage not moving
just got my hurricane project running good enough to go down the road today. i noticed my temperature guage didnt move, and was wondering what would be the easiest way to diagnos. or the easiest way to figure out if my water pump is good. it didnt get burning hot when i ran it (even tho it was 20 degrees out) but i would still like to know what temp its at. and yes, there is coolant in it...
to
Old 02-03-2010 | 09:37 AM
MetaLord 9's Avatar
If it's 20 degrees out the bike just might not be getting hot enough to be in the temp gauge's range. The digital gauge on my Kawi doesn't even turn on until the bike hits 104 and if I'm riding it in 20 degree weather, I'm usually lucky if it gets up to 150 on the highway.
Old 02-04-2010 | 02:56 AM
KongBastard's Avatar
Mine doesn't come on until it is almost too hot. I have heard that from other owners as well.
KongBastard
Old 02-04-2010 | 01:56 PM
Billistic's Avatar
There is a green/blue wire that connects to the thermosensor which causes the temp gauge to operate. Disconnect this wire from the thermosensor ( located just below the filler cap ). Ground this wire to the frame momentarily with the key on and see if the temp. gauge changes position. If it does then the thermosensor is probably bad. You can also check the continuity of the thermosensor to ground. You should have some continuity to ground depending on coolant temp. Frame=ground. good luck!
Old 02-05-2010 | 06:42 PM
dewdog's Avatar
ok. so..the good new is that i drove it around for a while today and it finally started move. bad news is that it starts to over heat. i havent looked into it yet but i have a feeling its the thermostat. its probly stuck seeing as how the bike has been sitting some time
akrite
09-30-2013 03:22 PM
bambam
12-18-2009 01:33 PM
rdrink25
06-25-2007 02:01 PM
ericej2344
06-05-2006 06:08 AM
brian
10-24-2005 05:04 PM
