steering damper
Old Dec 9, 2007 | 06:40 PM
OLDbutFAST's Avatar
Default steering damper
Does anyone know much about steering dampers?I would like to put a damper on my 89' but I couldn't find any kits for the 600F (big surprise) so I plan on designing and making my own custom mounts the only problem is that I have never realy looked at them up close to see how they actualy mount.
also I know they make piston type and rotary typeI was kinda leaning toward the piston type myself
Old Dec 10, 2007 | 12:51 AM
michigan_313's Avatar
Default RE: steering damper
custom tubular side mount with bolt bosses welded into the main frame spar. f2 steering mount from f2 kit.
[IMG]local://upfiles/5094/71E1BD42F146448DA36824A55F91B556.jpg[/IMG]
Old Dec 10, 2007 | 05:16 PM
racerrick's Avatar
is it really needed?
Old Dec 10, 2007 | 07:32 PM
OLDbutFAST's Avatar
ORIGINAL: racerrick
They will slow down steering input, and their primary benefit is found on bikes which get their front wheels light or off the ground altogether under acceleration. They’ll help prevent you from turning the wheel while it’s light/off and thus produce a wiggle, wobble, or tank-slapper when the wheel is loaded up again
and its just another custom mod
wobble = [:'(]
Old Dec 11, 2007 | 12:41 AM
at the time i had the stock frontend, it probably wasn't needed, probably.
but i've since swapped my frontend for a complete 600rr. now it is needed. and not because the frontend gets light. it is because the steering geometry changed.
Old Dec 11, 2007 | 02:53 PM
OLDbutFAST's Avatar
i've also been hearing that different tire combos can cause some wobble. either way i have a slight wobble and i want it gone lol
Old Dec 11, 2007 | 06:56 PM
that is true, too. it has not happened to me, but i have heard from others who were mixing brands that it has happened to them. sport tires but with different tread and profiles.
Old Dec 11, 2007 | 07:00 PM
https://cbrforum.com/m_222648/tm.htm
if you look at dementedf3's pics, you will see a black side bracket. that is what comes with the hyperpro kit.
Old Dec 11, 2007 | 10:38 PM
Gogar's Avatar
There's one on my bike, I'll try to get some pics for you.
Old Dec 12, 2007 | 02:38 AM
Kamakazi's Avatar
Before you spend god knows how much on a damper, and weld or drill into your frame contemplate this: Do you think these bikes wobbled when they rolled out of the factory-- nope. When I bought my Hurricane it would wobble at high speed. Anyways, turned out that I had a bias tire on the rear and a radial on the front. I got two new radial tires at the same profile and all problems went away. Heck, your problem could even be worse than that-- check your bearings too.
Putting a damper on would only be a half *** attempt at covering up something that needs to fixed right.
