Startup after winter downtime
Hi guys, I'm new to the forums. I've got an '89 Hurricane I've been wintering in a friend's garage. Unfortunately, when I put it away I was a bad, bad owner and neglected to read any advice on the proper procedure for winterizing a bike. Meaning I put it away with a full tank of gas and 2500-mile old oil in it. I even left the battery in... *hangs head*
The good news is, the garage doesn't get very cold since my buddy keeps it heated for his snowmobiles. When I went to try starting it this past weekend, the battery had a full charge, and it cranked over strongly. However, despite a lot of trying, I wasn't able to get it started. Now I know I'm gonna have to drain the gas at the very least, but is there anything else I should be looking for before I try to start it again? I haven't done the usual gas/spark/compression checking cause I figured it was just water in the gas, but now that I think about it, I wasn't smelling any gas after all that cranking. I need to drive it about 50 miles back to my place before I can do any major work on it, but if it's something minor I should be able to do it there.
Needless to say, I've learned my lesson about winter prep. Thanks for any help guys!
-Fisher
-Fisher
Fuel was on. I've never really used the petcock, so I didn't even think about turning it off when I put it away. If it turns out the carbs are clogged, what's the easiest way to clean em out? I've never taken the carbs off before, and I don't know anything about resyncing/ etc. when I put them back on.
Easiest way to clean carbs, lol. Take them apart, clean, re-assemble.
...sorry, just wanted to make sure you knew I wasn't ragging on you. Just thats the only way. I mean, I guess you could try some carb cleaner or something similar, but if they are dirty and preventing the bike from starting, they should probably be cleaned manually.
