speedometer
Old May 6, 2008 | 08:30 PM
ken12's Avatar
Default speedometer
mygauge says im going 5 mph faster then im actually going. what does everyone think i should check? i have 32,1xx on it, do you think its just the cable or what? thanks ken
Old May 6, 2008 | 08:33 PM
mitchedwards81's Avatar
Default RE: speedometer
is it the stock size tire?
Old May 6, 2008 | 08:37 PM
ken12's Avatar
yea the front and rear are both 17's the sidewall in the front is an 80 but i dont think that would effect it
Old May 6, 2008 | 09:20 PM
Gogar's Avatar
If your front is a 110/80-17 that's the right size. Remember though, that the second number is not the actual height of the sidewall, just a proportion of the width.
110/80-17 vs 120/80-17 the sidewall on the second tire will be (barely) bigger.
Anyway, a bigger sidewall would make your speedo read too slow, not too fast.
It's probably fine. Many manufactures build in a little "extra" on their speedo readings. If a manufacturer made a speedo that, say, read too slow and someone got a speeding ticket they could conceivably look for recourse with the manufacturer of the vehicle for the speeding ticket.
If they build the speedos a tiny bit too FAST, they don't have this problem.
Old May 7, 2008 | 05:14 PM
ken12's Avatar
thanks gogar..so no one else has any problems with their speedo?
Old May 7, 2008 | 05:29 PM
michigan_313's Avatar
i have problem but that is because i relocated mine to the output shaft. it works but is about 15mph off/faster.
Caleb
May 8, 2009 12:08 PM
90f1rider
Apr 23, 2007 12:08 AM
