Speedo error
Old Jul 11, 2008 | 01:25 PM
mj_wils1970's Avatar
Default Speedo error
Hi,
This one is driving me nuts... when the bike is moving, the odometer climbs as it should but the speedo doesn't move.
However, I disconnected the cable from the wheel portion and attached a drill, running the drill moves both the speedo and the odometer.
any ideas??
Thanks,
Mike
Old Jul 11, 2008 | 02:15 PM
ffjoey's Avatar
Default RE: Speedo error
Bad speedo cable. Now go to your room and think about what you have done.
Old Jul 12, 2008 | 01:20 AM
drakito's Avatar
Could be a bad wheel gear, the part the cable goes into down by the wheel. It easy, if you had your tires changed, for the shop to not put it back on correctly, or you. I've done it, I caught it before the road test, but its easy to do.
Our cables do break frquently enough to need some TLC and checking at regular intervals. If you can pull the cable out of the connector or if half falls out, get a new one. Also makes sure and lube it up good, disconnect the top by the speedo and pressure lube down the cable.
Old Jul 12, 2008 | 04:27 PM
tripicana's Avatar
its not the cable because the odometer part is turning. something is wrong with the speedometer pickup. probably need a new speedometer
robbiebgraham
Oct 22, 2010 10:32 PM
gangofhoes
Apr 22, 2009 12:54 PM
batmx3man
Jul 7, 2008 08:51 PM
celborn
Apr 30, 2007 10:18 PM
sauce
May 20, 2006 05:47 AM
