Pc19/23 engine swap??
Old Jul 19, 2023 | 11:26 AM
3bikes1will's Avatar
Default Pc19/23 engine swap??
Hi all, I've got a pc23 with a blown headgasket, have ordered a gasket kit but I need the bike next Wednesday for a trackday. I have an engine from a Pc19 that I got off Facebook, anyone know if it is a straight swap and if all the parts are compatible?
Thanks
Will
Old Jul 19, 2023 | 06:47 PM
dannoxyz's Avatar
Not sure about physical mounting aspects. But extremely different engines. You'll need to get PC19 carbs, wiring-harness and ignition-module for it to work properly. Cancel or sell the trackday and take time to fix bike properly. Make sure you measure flatness of head and deck and get them machined flat if needed. Any rushing and missing step in replacing headgasket will destroy engine and you'll have to pull it yet again!
Also find out why it blew headgasket and fix it. Don't just throw new headgasket on and go on, problem is still there and will blow new one as well. Could be:
- overheating due to failed fan
- overheating due to failed fan circuit
- overheating due to failed fan thermo-switch
- running lean due to clogged carbs
- running lean due to mis-adjusted carbs
- too much compression from carbon build-up
- too much ignition-advance for octane-level
- etc.
Find actual cause of blown headgasket and fix it. BHG is just symptom or result of actual cause, whatever that may be.
Old Jul 19, 2023 | 06:49 PM
Hi thanks for the reply.
Do you know what the differences are? I was under the impression that the only mechanical differences were the cams and carbs and was hoping I'd get away with the pc23 carbs. Obviously wouldn't be ideal but as I need the bike for next Wednesday seemed like my best option.
Old Jul 19, 2023 | 06:53 PM
dannoxyz's Avatar
Whoops, sorry I was thinking of PC25 F2 engine.
Sure, should be able to use it with PC23 carbs and it'll probably run slightly rich. No biggie.
Old Jul 19, 2023 | 06:56 PM
Sweet thanks, I'll try it tomorrow and report back with results
Old Jul 21, 2023 | 11:08 AM
Not got the engine in the bike yet, but just used some compressed air to blow any dust out of the cylinders and in doing so I think I've found a problem. When I blow air into cylinder 3 it comes back out the top of cylinder 4... I'm fairly sure this shouldn't happen?
If I'm worrying over nothing please let me know guys
Cheers
Will
Old Jul 22, 2023 | 12:22 AM
dannoxyz's Avatar
Sign of blown headgasket. Burned channel in gasket between cylinders
BHDJ F2
F2 Tech
19
Aug 16, 2012 07:31 PM
kingyeddi
May 26, 2010 03:23 PM
kdmac03
Jul 8, 2009 04:45 PM
blkhwn
Jun 29, 2008 02:30 PM
buff_bills1983
Jul 22, 2007 12:19 PM
