Parasitic draw
Old Mar 22, 2015 | 08:35 PM
Emmanuel Lind Chrisalos's Avatar
Default Parasitic draw
Hi all, Happy new season for all of thous that the motorcycle season has started.
Well I'm at it again. I am having some electrical problems, my battery is getting drained when the bike is not in use. I have manage to narrow it down to the regulator rectifier. I did a step by step check following the instruction of the manual and removing everything and then connecting one by one. Conclusion, as soon i connect the rr i get a reading of 12v dc. My thought is that the draw is between the start relay and the rr. Any thoughts and tips on the matter would help a lot. Thanks in advance
Old Mar 23, 2015 | 07:34 PM
drakito's Avatar
The RR should not be drawing any current when the bike is off. Sounds like it is possibly bad. BTW 12VDC is the voltage. You should be looking for Amperage. A standard draw with everything off should be .01A to .00A Anything higher than .25A will kill the battery in short order.
Old Mar 24, 2015 | 09:21 AM
The Honda manual says
"LEAKAGE INSPECTION
Check for battery voltage leakage before making the regulated voltage inspection. Turn the ignition switch off and disconnect the battery negative cable from battery. Connect the voltmeter between the negative cable and the negative battery terminal.
1. The voltmeter should indicate 8V with the ignition switch off.
2. Disconnect the regulator/rectifier 3P and 4P connectors. The voltmeter should indicate 0V with the ignition switch off.
If there is Ok for step 1 and 2, there is no leakage"
The Haynes manual refers to mA tho its for the US 600 models
Old Mar 25, 2015 | 07:12 PM
drakito's Avatar
I see, it is showing the voltage drop across the system. Amperage is a harder test to do and requires more work.
the12volt.com will help with how to use the meter and why it works the way it does.
As to your reading of 12v. If I am understanding the screwy instructions correctly, it should read 8 volts. Therefore it is out of spec and needs replacement.
Old Mar 25, 2015 | 08:19 PM
I assume that you are referring to the multimeter?
By the way about replacing the rr it was my first thought to and i did. Got the same readings all the same
Old Mar 25, 2015 | 10:57 PM
74demon's Avatar
Do you have a 12v test light?
Put the test light in series between the positive cable and the battery. If it lights up, that's your draw. The brighter, the larger the draw. Start pulling fuses one at a time until the light goes dim or out. Then look at that circuit for the problem by unplugging things until the light goes out again.
soonerbillz
Jul 18, 2013 10:54 AM
tomttt
Feb 20, 2011 06:12 AM
Turbulenz
Apr 30, 2010 05:05 AM
Kuroshio
Nov 23, 2009 08:21 AM
SmokeShank
Jun 30, 2008 12:51 PM
