Oil Cooler
Old Jul 11, 2009 | 08:42 PM
87CBRFighter's Avatar
Default Oil Cooler
Does anyone know where I can get the fittings for the oil cooler? I don't need the stock hose setup because I have rerouted the oil cooler and have it connected off of the radiator since I'm not putting any of the front supports or plastics back on it. I need to get a hold of the fittings that connect to the oil cooler so I can have some custom hoses made, since the stock ones are too long.
Old Jul 12, 2009 | 01:53 AM
KongBastard's Avatar
If you have a pic of where you mounted it I would like to see it.
As for your original question - I am not sure it the fittings are custom but is it possible to cut them and splice them back together?
I think I have some used lines in my garage so I will take a look and see if I can answer my own questions.
KongBastard
Old Jul 12, 2009 | 03:11 PM
kpshogry's Avatar
I agree, pictures of relocation are a must, I'm trying to do this same thing on my fighter.
Old Jul 15, 2009 | 01:18 AM
I found my spare lines tonight. The id of the line is 3/8" (10mm) od is 3/4" (20mm).
The fittings look custom to me but I don't know much about that so maybe they are available. They have an o-ring seal and the fittings are swaged onto the lines.
The lines have no reinforcement other than the outer fabric braid.
I can't see why a person couldn't just cut the line where it won't show (under the motor?) and splice it together using a piece of copper pipe with an od of 3/8ths and clamp it on either end of the tube.
I sure if you take the fitting to a machine or plumbing shop they can tell you if it is a regular fitting or something "unavailable"
KongBastard
airick
Oct 12, 2007 01:31 PM
KidCr3nshaw
Jun 11, 2007 02:02 AM
900rr_Guy
Mar 16, 2007 07:28 PM
