octane?
Old Jun 20, 2012 | 12:54 AM
89HurricaneF1's Avatar
Default octane?
Just curious what octane everyone uses and also location if ya could...... Tryin to figure out which octane level is best for my 89 cane......
Old Jun 20, 2012 | 06:00 AM
74demon's Avatar
There is a label in the bike that will tell you, or look in the owner's manual. This has been discussed before, and the consensus says 87 octane or equivalent.
Old Jun 20, 2012 | 06:33 AM
sjona2011's Avatar
i always run 91/93 in my f3.
yes the manual may recommend a lower octane, but with the higher compression ratios that these bikes have, why risk it?
running a lower octane wont have any immediate effects, but in the long run it will extend the life of your motor.
Old Jun 20, 2012 | 11:42 AM
trippmann's Avatar
i always ran 89, my bike was a 1989 so i figured it would be suiting
Old Jun 20, 2012 | 12:17 PM
74demon's Avatar
How much compression are you running? More the 12:1?
Higher octane is a slower burning fuel and burns at higher temps. So unless your bike is tuned for it, your wasting your money and hurting your performance a little.
Old Jun 20, 2012 | 05:32 PM
Conrice's Avatar
he's right. you're wasting your money 2 fold because a)it costs more and b)you use more of it to make the same amount of "bang" because it burns slower.
i always used reg.
Old Jun 20, 2012 | 09:04 PM
TahoeRider's Avatar
Yep regular grade fuel is fine unless you have mods done to your engine requiring running higher octane. Running a higher octane than needed for your engine setup doesn't help anything or provide any benefits.
Old Jul 10, 2012 | 02:50 AM
Halfpint's Avatar
On the frame, right rear fairing off, on the tail section there is a service specs sticker it says 91 Octane min. Also, all the valve adjustment, idle specs. etc.
Old Jul 10, 2012 | 07:56 AM
74demon's Avatar
What bike do you have? Must be a newer one than the OP. Some of the stickers say 91 octane RON, which is 87 pump octane in the US. If tour bike says to use 91, then use 91.
Old Jul 11, 2012 | 03:55 PM
Halfpint's Avatar
@74demon i have the 89 Honda 600cc F1 first generation.. California Emission.. California model..
