need help compression question
Old May 21, 2017 | 01:32 PM
Thepoliceknowmebymyfirstname's Avatar
Unhappy need help compression question
i have a 1990 cbr600 i bought i thought i would start by checking compression
the engine currently does not start so the compression was done cold
cylinders without oil 1- 95 2- 80 3-95 4-80
cylinders with fogging oil 1-110 2-100 3-95 4-90 i think these are low tryin to figure out if this motor has any hope motor has over 40,000 miles 40,000 abused miles
Old May 21, 2017 | 02:37 PM
74demon's Avatar
What is the specification for compression?
Adjust the valves and see if they even out a bit.
Old May 21, 2017 | 04:29 PM
I don't know the compression spec but I will check the values does any one know if the motor has to be dropped to adjust vaullves
Old May 21, 2017 | 06:48 PM
74demon's Avatar
You can check/adjust them with the motor in the bike.
download a manual for the specs. You will need it for checking valves as well.
Old May 21, 2017 | 06:57 PM
dennisgb's Avatar
Why are you doing a compression test? Did you try and run the engine and had a problem? These engines are pretty tough so would hope you ran it first before rushing off to do compression testing. It's difficult to get proper compression readings. You should look up the procedure in the shop manual.
Determining what might be at issue also takes more than just a compression test. A proper leak down test will help isolate whether there are valve problems or rings...assuming that engine was running poorly, which as I stated above is a critical factor.
Old May 22, 2017 | 01:04 AM
CaBaRet's Avatar
Hi , did you use wide open throttle while doing the test, if not the readings are invalid
mar s
Mar 7, 2017 06:53 PM
JJZF4i
Jan 11, 2011 11:00 PM
stinemonster
Aug 29, 2008 11:39 PM
Kc31019
Jan 22, 2008 09:12 PM
