ignition question
Old Feb 15, 2008 | 09:01 PM
eurobeaner's Avatar
Default ignition question
ok. i got my cbr a while ago. when i recieved it the only way to start is is to jump a wire ran from the + terminal to the yellow wire on the right of the handle bars... can anyone tell me what SHOULD go here? there are actually 4 wires.
1-yellow-starter
2-blue-headlight
3-black-??
4-black-spliced into another black that goes to the "sun/stop" switch
what is suppost to go here?
Old Feb 17, 2008 | 10:18 PM
eurobeaner's Avatar
Default RE: ignition question
anyone?
Old Feb 17, 2008 | 11:16 PM
michigan_313's Avatar
black/red goes to fuse box headlight.
yellow/red goes to 4p conn 30 amp fuse.
blacks tied together go to fuse ignition, start, fuel pump, and fuel pump relay.
white/blue goes to hi/lo light switch
black/white goes to ignition coils and spark unit.
Old Feb 19, 2008 | 05:24 PM
eurobeaner's Avatar
This is what im talking about.... i KNOW what they go to.. cause the only way to start it is take a previously runbattery hotwire to the "yellow" wire.. that kicks the starter on, then when you ride, push the wire to the blue one... BUT, what should these go to? shouldnt they connect to something?? theres is no "start" button on my bike...
Old Feb 19, 2008 | 07:18 PM
ugh....yeahhhhh.....
they should be going to the inside of the control pod on soldered contacts. you should crack yours open and see what happened to them. either resolder the wires (if you have enough length) back onto the contacts, or get a replacement control pod. yeesh... that's horrible.
should've just had a pic to begin with.
Old Feb 19, 2008 | 07:52 PM
eurobeaner's Avatar
well.. took me a min to figure out how to.. lol. and yea, thats hacked. can someone get a pic of what its SUPPOST to look like? theres prolly suppost to be a start button somewhere... mine dont have one.
Old Feb 19, 2008 | 09:02 PM
the pic with the white box, you should see 2 contacts for the starter button.
[IMG]local://upfiles/5094/3F6CC0A486DC4D319F591C469913B7FE.jpg[/IMG]
[IMG]local://upfiles/5094/0277ED8FC2CE4A4DA319C7D10443AFC6.jpg[/IMG]
[IMG]local://upfiles/5094/D816B09737124CB5A88B0CD419EAF308.jpg[/IMG]
Old Feb 19, 2008 | 09:03 PM
the last one isthe underside of the top part of the control. start/stop switch.
[IMG]local://upfiles/5094/8521569059724D4E86B13E6745D0279E.jpg[/IMG]
[IMG]local://upfiles/5094/B5CF96F4D710445A86941280EDC42BE2.jpg[/IMG]
Old Feb 20, 2008 | 08:10 PM
eurobeaner's Avatar
OOOO. thank you very much michigan_313.
for one... how is that control all nice and black? and for 2, i dont have a start button period. which is prolly why the guy did what he did. i need a whole new control now. time to call cycle recycle.
Old Feb 21, 2008 | 12:18 PM
i bought control that way hidden away from the sun. i guess one could soak the plastic in black ink and see if that works.
if you need a start switch, you could probably find a small momentary switch to put in the hole where the original switch used to be.
http://www.action-electronics.com/switches.htm
http://www.kpsec.freeuk.com/components/switch.htm
SilverF3
Sep 26, 2008 08:57 AM
JDubF4i520
May 13, 2007 09:47 PM
Pacs_Legend
Nov 9, 2006 07:38 PM
Applejax
May 10, 2006 11:47 PM
Applejax
May 8, 2006 02:55 PM
