ignition question
ignition question
ok. i got my cbr a while ago. when i recieved it the only way to start is is to jump a wire ran from the + terminal to the yellow wire on the right of the handle bars... can anyone tell me what SHOULD go here? there are actually 4 wires.
1-yellow-starter
2-blue-headlight
3-black-??
4-black-spliced into another black that goes to the "sun/stop" switch
what is suppost to go here?
1-yellow-starter
2-blue-headlight
3-black-??
RE: ignition question
This is what im talking about.... i KNOW what they go to.. cause the only way to start it is take a previously runbattery hotwire to the "yellow" wire.. that kicks the starter on, then when you ride, push the wire to the blue one... BUT, what should these go to? shouldnt they connect to something?? theres is no "start" button on my bike...
ugh....yeahhhhh.....
they should be going to the inside of the control pod on soldered contacts. you should crack yours open and see what happened to them. either resolder the wires (if you have enough length) back onto the contacts, or get a replacement control pod. yeesh... that's horrible.
should've just had a pic to begin with.
the pic with the white box, you should see 2 contacts for the starter button.
[IMG]local://upfiles/5094/3F6CC0A486DC4D319F591C469913B7FE.jpg[/IMG]
[IMG]local://upfiles/5094/0277ED8FC2CE4A4DA319C7D10443AFC6.jpg[/IMG]
[IMG]local://upfiles/5094/D816B09737124CB5A88B0CD419EAF308.jpg[/IMG]
i bought control that way hidden away from the sun. i guess one could soak the plastic in black ink and see if that works.
if you need a start switch, you could probably find a small momentary switch to put in the hole where the original switch used to be.
http://www.action-electronics.com/switches.htm
http://www.kpsec.freeuk.com/components/switch.htm
