ignition fuse blows
Old Nov 23, 2010 | 12:45 PM
apollo's Avatar
Default ignition fuse blows
hi,have a problem with my CBR 600 FJ 1988,when I turn on the ignition & press starter button the ignition fuse blows,10amp,in the fuse box [under the left hand side handlebars].I have tried some tests ,including cleaning & testing continuity of starter botton,putting in a new battery,checked all fuses including 30amp main fuse on solanoid put in new solanoid,then I got to the fuel pump cut off relay.This is what happens,when the fuel pump relay is connected in normal way.-Turn on the ignition & it's OK,press starter button & the fuse blows.Then if you disconnect the fuel pump relay & put a connecting{annex} wire betwean the Blue/Black blue wires in the connection plug of the relay,when you turn on ignition[but don't press starter] the same fuse blows.Any ideas
Old Nov 23, 2010 | 05:09 PM
thrasher572's Avatar
It sounds like you have a short circuit in the fuel pump. I have seen one of the internal leads come unsoldered in there...maybe it is shorted to the case. The black plastic cover is removable for inspection.
Old Nov 24, 2010 | 08:58 AM
apollo's Avatar
Hi Thrasher,good call,checked over fuel pump,looked inside,gave a squirt of wd40,tried it out on bench,went OK.Put on bike & it turned over without blowing fuse,so found where fault is,iether it was stuck or shorting somewhere.THANKS
Old Nov 24, 2010 | 01:57 PM
Ya can't ask for better than that! Glad you found the fault.
Old Nov 25, 2010 | 09:02 AM
apollo's Avatar
Smile ignition fuse blows
Saved me a lot of time & money from going to stealers,probably would charge me a days wages to find problem.Knowledge is power.
doogstar
Jul 16, 2019 05:11 PM
Decepticon42
Sep 17, 2011 09:16 AM
idris
Jun 27, 2011 01:18 PM
01hondaf4i
Apr 13, 2011 01:23 PM
DrexNX
F2 Tech
18
May 24, 2010 01:25 PM
