hurricane stunt project?
Old Apr 15, 2008 | 02:51 AM
joesmith209's Avatar
Default hurricane stunt project?
im thinking about turning my cane into a stunt bike. what does anyone else think?
i was thinking the following things
-change sprocket
-handle bars
-i know someone that can fab a cage
-possibility of bigger tires?
any other ideas?
has anyone done this?
Old Apr 15, 2008 | 01:07 PM
michigan_313's Avatar
Default RE: hurricane stunt project?
i've seen all that stuff done. you won't get a huge tire to fit. 150 section will be about the extent especially if you are going to be running low pressure you will have to see it the edge of the tire clears the chain.
if you are going to do wheelies, the front forks won't last long, specifically the seals. those will get bombed out pretty quick.
handlebar you'll need to reinforce the top clamp underside so that the risers won't break off or crack the top of the clamp surface.
large sprocket kits are available.
short term i think the bike will be okay for stunting, but be weary of the left side engine mount plate. there have been reports in this forum about frame cracks on that side.
bagtag101
Mar 17, 2010 02:53 PM
600f4iHUNTERDON-NJ
North East
Oct 9, 2009 09:30 PM
Rockford
Sep 5, 2007 06:00 PM
BLUE DIAMOND
Nov 8, 2006 12:34 PM
