NEED HELP ON PROJECT STUNT HURRICANE
Old Oct 24, 2006 | 02:02 PM
BLUE DIAMOND's Avatar
Default NEED HELP ON PROJECT STUNT HURRICANE
Hi everybody here's the deal i just got a real sore old hurricane. Starter didn't want to turn the motor over so I jumped the starter with some booster cables and man she lit up but did not start. I've come to realize that the ground off the starter is real ****ty hence the no roll over but now it does not seem to want to start. Where do I go now??(IT'S GETTING FUEL BUT NO FIRE)
Anybody have a wiring diagram?????
Old Oct 24, 2006 | 02:34 PM
rrasco's Avatar
Default RE: NEED HELP ON PROJECT STUNT HURRICANE
what year is it? i have the 89-90 wiring diagram scanned in. if you need 87-88 let me know.
have you tested the solenoid?
Old Oct 24, 2006 | 02:43 PM
STARTER SOLENOID?
Old Oct 24, 2006 | 03:21 PM
michigan_313's Avatar
that would be the start relay at the top right of the diagram just after the battery.
Old Oct 24, 2006 | 03:30 PM
WELL IT SEEMS TO WORK. WHEN I TRY TO START THE MOTOR IT JUST DOESN'T MAKE AN ENTIRE REVOLUTION IT CUTS OUT LIKE THE BATTERY IS DEAD AND JUST "TICKS" AFTER A HALF REVOLUTION. I FIGURED I HAD A BAD GROUND BECAUSE WHEN I BYPASS IT SHE TURNS LIKE A BANSHEE
Old Oct 24, 2006 | 04:09 PM
HOW THE HELL CAN I PRINT THAT DIAGRAM....
Old Oct 24, 2006 | 04:30 PM
rrasco's Avatar
ORIGINAL: BLUE DIAMOND
i dont know, you will have to mess with your printer settings. I just made it a big image for the web.
back to the problem, so when you try to start the bike normal, it begins to turnover and then begins clicking? Where is it clicking coming from, below the seat to the right? If so, that is the starter solenoid, its round with 2 contacts (1 from battery, 1 to wiring harness) and the main fuse. Use a screwdriver or remote switch to complete the circuit bypassing the solenoid. If it begins to turn over, its either the solenoid or the wiring from the start button.
Old Oct 24, 2006 | 04:50 PM
NO NOT THE SOLONOID THE STARTER CLICKS LIKE POWER ON AGAIN OFF AGAIN AS IF THE BATTERY WAS DEAD
Old Oct 24, 2006 | 04:54 PM
IT JUST DOESN'T HAVE ENOUGH POWER TO MAKE A REVOLUTION
Old Oct 24, 2006 | 05:28 PM
AHHHH PRINTED THANKS SO MUCH!!!!
THIS SHOULD HELP A LOT TONIGHT..........AT WORK NOW!
