Hurricane oil catch belly pan
Old Jul 22, 2013 | 12:18 AM
seandcontracting's Avatar
Default Hurricane oil catch belly pan
Doing a 87 600F for road racing...I require a belly pan for catchment of 4 to 5 litres for oil, coolant etc. any ideas, anyone? Thanks!
Old Jul 22, 2013 | 10:21 AM
drakito's Avatar
Custom fab one yourself.
Use a FIA certified transmission catch blanket for a car.
Swap all your body plastics to a bike with a catch pan.
Don't forget you will need to drill your axles, headers, head tubes, and just about every stressed bolt on the bike for safety wire...
A good how to is here: http://amaproracing.com/rr/news/index.cfm?cid=51703
Old Jul 23, 2013 | 12:19 PM
CorruptFile's Avatar
June 2013 ROTM
Where are you going to be racing?
Old Jul 23, 2013 | 02:42 PM
Mission raceway, British Columbia. Also, regarding the second post, of course I can fab one. I merely wanted to know if anyone knew of one ready made. Would like to keep appearance close to stock.
Old Jul 23, 2013 | 04:12 PM
drakito's Avatar
Nobody has made one for the hurricane for production. By the time belly pans were required on bikes the hurricane was already out to pasture. The F3 had come out and came with it standard. Most tracks will let a FIA certified catch blanket work instead of the pan. A FIA certified transmission blanket is fairly cost obtainable and will fit under the stock plastics, with some minor modifications. http://www.summitracing.com/search/p...ssion-blankets
Make sure and check with your track to make sure they are ok with a catch blanket instead.
Old Jul 24, 2013 | 12:35 AM
Drakito, thanks for the thorough explanation, I had not thought of the era. I raced in 87-88 and am now returning....never occurred to me to use a blanket. Thanks!
Old Jul 25, 2013 | 05:17 PM
June 2013 ROTM
Awesome. I'd love to check out your 'canes sometime. IIRC you are upisland?
Old Jul 26, 2013 | 09:32 AM
Corruptfile, I'm just south of Nanaimo.
seandcontracting
Nov 7, 2014 02:04 PM
wooferdog
Jul 10, 2012 04:37 PM
MotoDan
Oct 29, 2008 08:29 AM
voodoochyl
Jul 15, 2007 11:26 PM
nakedf4i
Aug 21, 2006 01:07 AM
