Hurricane cylinder washing
Old Sep 11, 2025 | 10:14 PM
Moonlight2391's Avatar
Default Hurricane cylinder washing
Bike has had cylinder washing before, blamed it on a leaking float and the petcock in the on position for 2 days causing the entire tank to drain into the crankcase and fill the cylinders up to the carbs, after rebuilding engine with new rings and valves and the carbs were rebuilt and floats were checked I thought I was having a issue with my fuel pump not supplying enough fuel to the engine so I bypassed the fuel pump and went to gravity feed from the tank for testing purposes, the bike still starved of fuel even on gravity feed, shoved a bore scope into the tank to find the filter is clogged with sediment. After discovering this I turned the petcock to the off position so I would not have cylinder washing again, waited a week for parts to come in only to find when I was pulling the fuel lines apart that all the gas magically disappeared in the lines, so I figured it was either evaporation, a leak in the line, or it somehow got into my crankcase again, I pulled the oil cap and it smelled very faintly of gas. I have not started or cranked the engine in fear of it destroying the crosshatching, what should be my next step? I know I have to change the oil and refresh the oil on the cylinder walls, how much oil should I pour down into my cylinders? How do I fix the carb leaking issue to ensure this stops happening? Its getting very annoying seeing i have changed the oil 5 times because gas is contaminated it.
Old Sep 12, 2025 | 11:24 AM
Other than bad floats, or needle valves, I don't know what it could be. On your gen, can you adjust the float height?
Old Sep 12, 2025 | 11:46 AM
yes, they are set to 8mm by the manual, I started tearing the carbs apart again and noticed in the manual there are tiny filters behind the float needle, when I pulled the filter it wasn't clogged but around everything was dirt. Does this needle look worn?
Old Sep 12, 2025 | 12:13 PM
It's hard to tell from a picture if it's worn. The best way to tell is to depress the little valve stem on the top. It should display resistance when you push it down. It should snap back smartly when released. If you have everything assembled and push the float all the way down, it should have some bounce in it if you release pressure quickly. If you compare these characteristics to the other needle valves, they should all be pretty much identical.
Old Sep 12, 2025 | 01:25 PM
I left the carbs sit above the boots and I put a towel in each port to see which carb was leaking, the towel in 1 had alot of gas and 3 had a little, 2 and 4 were dry. The needles are good, the bounce back test revealed carb 1 has little to no bounce back, carb 2 has very good bounce back, and carb 3 and 4 have questionable bounce back.
Old Sep 12, 2025 | 02:41 PM
If it were me, I'd just replace them all. You already have it taken apart, which is the lion's share of the job. The needles themselves are pretty inexpensive.
Old Sep 14, 2025 | 04:54 PM
I bought a carb rebuild set and im going to replace everything, now for the clyinder washing in order to restore the oil on rings how much oil should I pour down the spark plug hole?
Old Sep 14, 2025 | 08:50 PM
A healthy tablespoon should do you good
Old Sep 24, 2025 | 12:35 PM
After I installed the new needle seat, needle, and adjusted the float height to precisely 8mm it still leaks with fuel in the bowls. I was running the tank straight to the carbs to fill the bowls and they just started pouring gas out of the bottom. I put them on the bike and put a towel across and all 4 carbs are leaking gas down into the engine
Old Sep 24, 2025 | 01:54 PM
Ed Harris's Avatar
It sounds like the valves you’ve been supplied with are too short. Adjust them to just beyond the point where they close the fuel feed.
